2011 F250 Crew Cab
  • 6
Cbarnwell5
I’m removing the factory sub and amp behind the seat of my F250 and was going to install my two 12” subs I already have from another truck but while calling around for a behind seat enclosure I’ve had several people say that I would better sound and bass for a behind the seat setup running 4 8” subs instead of 2 12” subs. What’s everyone’s thoughts on this? In my other truck I noticed that the louder I turned up the head unit that the bass with the 2 12’s would get less so I wondered if maybe that was due to lack of air space for them. Just picking everyone’s brain and if you have pics of your setup that would be awesome.
How’d you get the signal to the amp? If you spliced in from factory wiring then the factory signal cuts back on the bass the more you turn it up. I personally prefer 12s over anything else. How much airspace do you have to work with?
This place seems to go thru an 8" phase every now and then. Not gonna lie I even tried it myself once. Tried almost every eight there is in every configuration. Ran four 8"s for awhile. Something I will never do again. I'd take two big 12"s over four 8"s any day.
697
Probably the adapter brand. Other users have found that the pins do not coincide with the factory pinout guide. They have solved this by pulling...
HUGE thanks to everyone who contributed in here to helping me determine my amp was the issue. You guys were great. I now own a multimeter which...
53
6K
Hi crew! I’m reaching out for some help. I have a 2011 Fiesta SES and have all the parts needed for a conversion to Sync 3 except the harness...
Cbarnwell5
Cbarnwell5
South Carolina
hispls
