97 suburban 12 15s in a 6th order
  • 5
tc3k101
Ω
9,496
17
Socal
Here's what my build consisted of. As of right now it's in current tear down. I'll be upgrading for this next season. I am on team Deaf Bonce so that's what my upgrade will consist of.
12 15" alphard audio Super Sports
3 taramps md8000 and then to a taramps bass30k
16 Alphard Machete mm-80 mids
8 alphard ap25-t
1 lanzar 700*2 on midd
1lanzar 250*2 on tweeters
Lots of 1/0 off wire
200ah cmax
Some more pictures
Decided to paint it in my garage. I drove this car from La to Slamology last year. Had some bumps on the way and back ended up smoking the transmission.
This build was able to play 14hz-50hz no problem full tilt. I was never able to get the power the subs needed. We clamped 7k out of each 8k rising to 1.4 ohms. 17k out of the bass30k wired at 1.3 with unknown rise.
I'll try to find better videos but these are all from last year and I broke my phone in-between then. This build was nuts for budget equipment. This next season should be a lot better as I'm getting subs with higher xmax that will better suit my box. Each side of the enclosure is close to 24ft^3 so it's a small 1:1
  • received_304319300218873.mp4
    2.8 MB
  • received_1355456187954763.mp4
    15.2 MB
  • received_1428545677280218.mp4
    7.8 MB
  • received_2423585124337935.mp4
    10 MB
  • received_434454793845693.mp4
    1.2 MB
  • received_731689600595008.mp4
    6.6 MB
  • received_515930565840136.mp4
    16.5 MB
  • received_2119883634983674.mp4
    2.7 MB
  • received_271662920543864.mp4
    3.9 MB
  • received_404403723831254.mp4
    6.8 MB
What sort of numbers was this doing?
I think we did a 59.1 @29hz but we had so many different issues. My amps would walk the gain because of how much movement was in the rear. Subs were hardly ever in phase. Once we got things in phase all the lag bolts holding the box together started to snap from the body of the truck moving so much.
Nice. Hopefully when you rebuild you don't break as much stuff next season.
What size was the rear chamber? And how big was the front port
Never saw this. It's a 1:1 each chamber is close to 25 cubes. I don't remember how big the port is.
Update since I'm slow at installing.
Now going to run
12 Avatar Stu 15s
12 Alphard aab 4900.1
16 Sylvester 8" mids
8 ap 25t neo tweeters
2 aak 200.4
Aru 3000/2
500ah cmax.
I have the doors playing and these mids absolutely kick ass. With my box they have a good amount of midbass. Extremely loud. I don't need to turn the amp up at all.
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
931
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
825
tc3k101
Ω
tc3k101
Socal
tc3k101
    May 31, 2024
    May 24, 2024
