Y splitter
  • 2
toyjoha
This must just be like livin' in Paradise...
In hooking up a parallel DVC subwoofer, coming from the left & right RCA's on the HU (has only front & back outputs, no subwoofer nor preamps) going to a class D amplifier, that has inputs RCA's for left & right regular or left & right bridge.
The front RCA's on the HU got to a different amplifier to 4 speakers front & back.
So the back RCA's on the HU needs to go to the class D amplifier. Do I
#1 use the y splitter coming out of the HU to a single RCA to either the left or right amp input?
Or
#2 use a double RCA cable coming out of the HU to the y splitter to the left and right RCA amplifier inputs?
Or
#3 use a double RCA cable coming out of the HU to the left and right RCA amplifier inputs? (I am guessing this is wrong since it is not mono)
OR
Something else maybe involving the bridge RCA inputs?
If you use the crossover in the head unit, then you aren't sending that part of the signal to the amp. (Whether or not that allows a more narrow...
991
This option is better because you need 3 pairs of RCA cables. Tweeters, midrange, and bass. You then use a Y at the amps on the Bass run, then use...
toyjoha
toyjoha
Key West, FL
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
