Need a Radar Detector Mount, help me out
Ive used the Escort branded version but went back to the two suction cups. My front windshield has 80% tint and just above the rear view mirror are small black dots where the tint never quite adhered. If that large suction cup doesnt have a perfectly smooth surface to mount to, it would fall off. 🤷🏼‍♂️
I wound up getting one that has a larger than regular suction cup, just a single one. I used to have 35% tint on my window, I wound up dash mounting my radar. This new suction cup I have has been pretty good so far, but it hasn't seen much use quite yet.
I have a 2006 Honda Odyssey with a 130amp factory alternator. I have done big 3 with ground to chassis and engine ground. I run a 2000watt RMS...
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
58
418
327
729
Buck
little alien on campus
Buck
Inside of a pyramid
Buck
    May 12, 2024
    May 11, 2024
