Amp Settings help
Hayden_b
I’ve recently purchased a pre build box with two twelve inch subs at 4 ohms and 500 watts with a JL audio 500/1 amp for my challenger. I also have a line out converter since I have a factory head unit. I have absolutely no idea how to tune the amp and would appreciate some recommended settings.
Thanks captain obvious. If it was that easy I wouldn’t be asking for help.
Sorry for taking the time to reply, First Mate. If you are that much of a novice, take it to a shop and let them tune it.
No need to respond, as I won't be able to see it. You only have 2 posts, and already being added to my ignore list for your brash comment. Congratulation.
The amp and converter
Also my amp doesn’t have a specified “gain” knob either
it'll say level or input sensitivty rarely does it ever get labeled gain.
Your audio control's main is the gain. The accubass is bass restoration, you want to use that and not the other bass knob that should be zero. You want the settings on the LC2i high and the amplifier gain settings low. After setting the audio control gains, put your amp gains at zero and any sort of bass boost option off. Proceed to play your hardest hitting music and raise the gain till it stops getting louder, then back it off a notch.
Very Appreciated I’ll come back with the results tomorrow.
set your gain right, heres how. test tones are at the very bottom...
You will need a multi-meter, a set of RCAs that will be sacrificed, and a small blade screwdriver. First disconnect the amp from the LC2i. Now cut...
Thanks for the info, made the setting changes and that did the trick. Toyed with the amp gain to get the amplitude balanced out, then tweaked...
How do you accurately set subsonic? Isn't the knob labeled in the vaguest of ways, a high and low value? Do you play a tone at desired frequency...
Hayden_b
Hayden_b
Oklahoma
Hayden_b
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
