Subs not working right please help
EthanD1
I have dual skar sdr 12's being run off a Skar RP-350.1D. This problem has been going on for a while. The problem originally started on the same amp but with my Skar IX 12's. They had been working fine for a month or two since i had the whole system installed but all of a sudden the subs started giving out and distorting when i turned the bass up over like 1/4 on my knob. I thought my subs might have gotten messed up after so much use so i replaced them with the SDR's but the second i played them after installing them the same exact problem occurred. I put in new rca's and it didnt fix it so it wasnt a blown rca. Someone please help. Im leaving a video of the problem below. In the video its playing super clean bass at first that you cant really hear but as soon as i turn up the volume it starts to distort and give out.
  • ips-9A6EF03A-50C5-4170-8467-F438ED622761.MP4
    6.2 MB
Sounds like there's some mechanical failure with those subs or something is touching the cones. If you have confirmed the subs aren't broken and there's nothing loose in the box touching the moving parts you must troubleshoot to see if your amp or source is the issue.
It reminds me if a thread where Lasherz explained that your source signal could get too high, therefore making your gain setting high enough to the clipping point. Clipping is where the signal becomes square instead of undulated. An undulated signal pushes and pulls the voice coil whereas a square signal violently shoves and yanks it. I believe this is where slinking of voice coils happen, until the cone becones stuck.
That is why I asked if it was both subs. The odds of both new and old subs being messed up are slim. So I figure it may be a strong signal or amp is bad. So try setting gains with a multimeter to see if that solves your issue.
Figured it out. For some reason my rca cables would work in everything but the new head unit. I quickly tried a spare set, and that fixed the problem.
The issue may be the sub box, not the equipment. If you got them prefabricated, chances are you got the wrong size an tuning.
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
If there is an OEM subwoofer, wire the NVX input to the wires that go to that sub. Then use the NVX RCA outputs to the amp RCA input.
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
840
EthanD1
EthanD1
4178 Heathcliff Dr.
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
