HELP! Wiring issues on Boss PV3700 amp and I'm too ignorant to figure it out
  • 2
Rowdyrod59
Installing a Boss PV3700 amp in my son's Durango. Ran all the wires like manual said, but the amp won't power up. Put my multimeter on the power and ground (key off - 0.00v), (key on - 0.00v); Ran a wire from battery ground to connect to my multimeter and rechecked (key off - 14.7v), (Key on - 14.7v). Checked the ground output from the amp to the car (neg multimeter cable connected to neg battery terminal, positive cable to amp ground - 14.7v with key on or off). Remote switch source (key off or on - 0.57v). I thought that maybe the problem so I made a jumper to supply 12v source. Still nothing. I don't know much about electrical and I don't know where to go from here. Any help is greatly appreciated.
688
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
Rowdyrod59
Rowdyrod59
Tucson, AZ
Rowdyrod59
Decebal
    Jun 10, 2024
