Small Case Denso Hairpin Alt Upgrade
  • 2
cas0586
WV
I have a 2003 Cadillac CTS with a stock 130A alternator. I have installed in this vehicle a set of morel tempo ultra 602s on a US Acoustics Barbara Ann and an Image Dynamics IDMax 12v3d2 on an Orion XTR1500.1. Using 1/0 royal excelene welding cable for main power/ground runs.
The stock alternator is failing and I figure an upgrade would be good. Likely going with a CES alternator unless there is any other opinions out there as reliable. With my current setup what should I upgrade too? I don't plan on adding equipment in the future. Options are 160A, 180A, 250A, 300A and 320A.
Thanks!
No a large case will not fit. There is barely enough room to fish the alt as it is. CES also confirms.
Get the alt with the highest idle output, but you may not need it on that amp. I'd install the amp with 1/0 and buy the alt if you need it
  • Locked
581
  • Locked
COMPLETED Small 4channel amp
I'm really tempted to grab a 4k db 🤔
19
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
cas0586
cas0586
WV
wew lad
    May 24, 2024
    May 23, 2024
