WOW! an infomercial product that actually worked!
To the OP post pictures of the results man!
It just rained today so when it stops raining tommorow i will wax it again and post some pics
Also i really like the meguires "Hot Shine" tire shine works wonders with dirty tires
Have you tried a clay bar? It doesn't really make it shine, but it makes the car ridiculously smooth. I wash my car often, but when I used a clay bar for the first time I could feel every imperfection in the paint and then within a couple swipes it was very smooth. It was pretty cool
clay bars god but I don't think that its good to use all the time because its used to remove clear coat and that good stuff, but every now and then I guess it wouldn't hurt
It is best to be used once every 3-6 months I believe. If used the wrong way, then yea it will **** up your clear coat. But, what it does is remove particles from the clear.
I know what clay bar does. It will **** up your clear coat if you use it on a dirty car without a lubricant. It would probably remove it if your clear coat is peeling, but if used properly, it doesn't remove your clear coat.
Yea, I was just adding to what you said in response to the other guy.
bumpincrv
bumpincrv
Illiniois
Injected54
    Jun 20, 2026
    Jun 20, 2026
