Need help!
  • 2
Hawaiiboy808
CarAudio.com Newbie
7
Hawaii
I have a skar rp800.1d amp running off stock electrical at 14.24 volts dc at 40hz but without having bass boost on I’m reading pretty low in ac volts coming out of the speaker outputs. But with bass boost on and using ohms laws I’m showing around 800 watts to my sub at 1ohm. And I know bass boost is not recommended but it seems impossible to gets the correct ac volts out of my amp without bass boost. All setting on my head unit are flat. I’m completely confused.
I’m running a kenwood ddx276 subwoofer setting turned on Max could it be from my set up. I recently added a second amp for mids and instead of pulling out the hu I split the rca and put full range for my filters on the hu
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
501
11
876
870
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
Hawaiiboy808
CarAudio.com Newbie
Hawaiiboy808
Hawaii
Hawaiiboy808
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
