SOLD FS: DD9512f w/dual 0.5's
  • 1
Hertz5400LincLS
1. Product: 1 Used Digital Designs 9512 "F" Subwoofer with dual 0.5 ohm voice coils
2. Specs:
Model - 9512f
Series - 9500f
Woofer Diameter - 12"
Voice Coil Diameter - 3"
Voice Coil Type - 4 layer DVC
Magnet Weight - 320 oz
Cone Type - Synthetic Fiber Blend
Power Handling RMS - 1200
Power Handling Music - 2400
Power Handling Peak - 4800
Suspension - 75mm
Nominal Impedance - 0.5
DC Resistance - 0.5
Free Air Resonance - 34 Hz
Qts - 0.31
Qes - 0.33
Qms - 4.15
Vas - 35 L
Le mH - 0.9
Sensitivity - 89 dB
Mounting Depth - 7 1/4"
Cut Out Diameter 11 1/16"
Speaker Weight 44 lbs
Full DD Write-Up on this sub --> http://web.archive.org/web/200603110...p?series=9500f
3. Description/Condition: Used Condition. This sub is 10/10 mechanically. From what I can see through the motor vents, the coil is still bright copper in color. Cosmetically, I rate this as 7/10. There are some scratches on the bottom of the sub. There is also some ca glue on the cone, but I am not sure why. There are no holes, rips, or tears in the cone from what I can see. There is a small blemish on the edge of the dust cap and there are some cracks in the finish of the dust cap. I bought this sub as a pair, but only intended to use one. I heard each sub individually and this one performed flawlessly.
4. Price: : $350 Shipped to the lower 48 - OBO, motivated to sell! - No Trades
I have ref's on CACo_Org under Hertz5400LincolnLS
5. Pictures:
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
169
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
474
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
949
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
895
Hertz5400LincLS
Hertz5400LincLS
Naperville, IL
Hertz5400LincLS
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
