Electrical problems
Jeepguy123
I have 2 amps one for subs and the other for highs. A 360 amp alternator and when I turn the volume up 3/4 or higher my gauge cluster, climate control lights, and head light flash on and off and have no clue what's going on. It never happened before until recently please help.
A while back a Jeep guy had the same issue. Did the Big 3 and regrounded all the OEM grounding points. That significantly improved the lighting. Still did it but barely noticable.
What amplifiers do you have? What subs? and running @ what Ohm load?What size is your supply wiring to the amp/amplifiers and fuse size under the hood, to what size make and model battery? Any secondary batteries at all or two? Has the Big3 been done yet? What size is you ground wiring at the amplifier/amplifiers? where is it grounded to?
More Information needed to try to diagnose the issues/issue
I have a 2006 Mustang GT and the alternator amperage is 135. I'm running 3 amps totalling 1600 amps, driving 2 subs, 4 - 6x8 and 2 - 6.5. Ive...
Update: The burning smell is slowly going away at middle volumes. To the point where it only comes on at middle volumes. I adjusted the sub master...
17
4K
Yea im mostly likely going to go that route. Dont plan on winning competitions or playing full tilt all the time. I watched some good videos last...
10
Jeepguy123
Jeepguy123
Michigan
Bobbytwonames
maylar
    Jun 2, 2024
    Jun 1, 2024
