Does amp need retuned?
  • 4
RamLimited
CarAudio.com Newbie
Installers wired my subs to 4ohms at the amplifier, even tho told them to do it to a 2ohm load. They tuned it and I hadn’t realized for months that they wired it to 4 ohm.
So question is: if I simply rewire the subs into the amp at 2 ohm, do I need to retune all the amp levels, or is it already set to the loudness of the receiver? Meaning i wouldn’t have to attempt to retune it myself, and could simply drop down to 2ohm without messing with anything?
There is no way it could be rewired to 2 ohms if it’s currently at 4 ohms. I’m assuming you have dual 4 ohm subs, which makes wiring options at 4 or 1 ohm. Dual 2 ohm subs can we wired at .5, 2 or 8 ohms.
There is no way it could be wired to 2 ohms if it’s currently at 4 ohms. I’m assuming you have dual 4 ohm subs, which makes wiring options at 4 or 1 ohm. Dual 2 ohm subs can we wired at .5, 2 or 8 ohms.
Yes it absolutely can. And that wasn’t my question
So I guess what I’m being told elsewhere is that 2 ohms at amplifier, is the same thing as 4 ohms x2. therefore if that’s true… then I don’t need to switch anything. Is this correct?
You have to bridge those......lol, right Rob?
I see that’s funny lol yeah I’m a noob with a Google education. regardless are these 2 setups: the 4 ohm x2 picture that I have now, and the 2 ohm pic I wanted to do… they are or are not equal?
Yes. It’s the same 2 ohm load in the end. A mono amp just bridges the 2 4 ohm loads at the amplifier. Doing it inside the box on the subs does the same thing.
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
476
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
Thanks everyone for the replies! Like I said in my first post I’m not wanting to be loud, I just would like to have a little extra bass.. I like...
12
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
RamLimited
CarAudio.com Newbie
RamLimited
Columbus, Ohio
RamLimited
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
