General box help American Bass XFL 15
  • 2
Vehicle : 02 volvo xc70
Location in the vehicle: Rear(It's a staation wagon so it's all open)
Space available (Length x Width x Height):
Subwoofer make and model: American Bass XFL 1544
Subwoofer Size: 15
Number of Subwoofers: 1
Type of Port (Kerfed, Slot, Aero, etc.): still to be determined
What type of music do you like?: Rap with some electronicish music
Is your goal SPL or Everyday Music?: Everyday but I like to get low
Tuning Freq (Hz): 32 or below
Hi my name is Dean, I recently purchased an Xfl 15 locally the guy also gave me a box for it. The box is freakin huge and impractical, its 8 cubes gross 5.66 net @ 28hz. Right now I have it on 600 watts and suprisingly it gets pretty nasty on the lows, now im in the process of designing a more practical box. From what I understand more space = more efficient, so if i were to build a box closer to 4 cubes on 800 to 1000 at a similiar tuning what would it be possible to surpass the current response to low frequency, or would it just be better to tune to a different freq for a flatter sound. Thanks Guys.
O ok, I just don't really know much about these larger woofers but I am definietly very happy with it. I just came from an sa12 in a 3 cube gross box so this thing just seems really freakin huge to me lol.
time alignment is not the same as volume. Time alignment is usually only needed when you have an amp or multiple amps, and one has a delay. I...
Looks like it's wire it either 4 or 8 ohm 🤔
4
852
Okay. Thank you so much! I will run individual power / ground wires to each amp. If the front of the car has no dedicated spot for tweeters, what...
880
You will need distribution blocks for the amps I would run 0 gauge to the blocks and 4 gauge to the amps. For the head unit I would us one that...
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
DeanG
DeanG
Boca Raton,FL
DeanG
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
