Epicenter and Equalizer setup?
  • 3
Max_034
Hello, I'm planing on installing a 4 channel amp and speakers to my current system which consists of the head unit, mono amp, and subwoofers. However I also want to install an equalizer and an epicenter but I'm not sure how to wire them. Should I do
1. Head unit → Equalizer → 4 Ch. AMP
....................... Epicenter → Mono Amp
Or 2. Head Unit → Equalizer → 4ch Amp
or maybe 3. Head unit → Epicenter → Equalizer → 4 Ch. Amp
............................................... ... Mono Amp
I'm sorry if you can't understand the diagrams but i think thats the easiest way to explain.
Thanks in advanced.
Depends on your eq and how you want to control it.
I have a basic 7 band equalizer, which I plan on keeping in the trunk. I want to control the bass with the epicenter control knob, which will be near the driver on the front. With that said what would be the best setup?
What do you mean? I'm sure that an EQ is used to process the sound level at different frequencies right? similar to a stereo EQ.
Turning up a EQ is just like bass boost and loudness. They are meant to cut peaks not boost, you can't add stuff that don't exist.
I have mused doing that, but I like keeping my jalopies looking OEM. Now if I knew how to fiberglass like NSTALN, I would have done it long ago.
22
after 40+ years in car audio, I've seen processors develop, peak and dissapear like old gym socks. the Epicenter was leagues ahead of its time...
6
985
I have a couple questions - Is it worth it to use both the MatrixPlus and the Epicenter ? I wanted to try it but I am having problems with where...
Max_034
Max_034
Chula Vista, CA
LosIsATool
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
