Alpine 7156 help
  • 2
RedRyder18
CarAudio.com Newbie
I bought an old Alpine 7156 headunit from ebay, did a bench test on it and it played a cassette, volume, fast forward, and rewind was all working like it should but my display is very dim, if I shade my hand over it I can barely see the clock which looked like it was not set correctly but working. Also while getting it to play I realized that I needed a 9 pin plug that connects to the harness on the unit which it seems I cannot find, talked to a couple local guys at electronics stores and they said I could splice the wires to get it to work, but I'd like some more opinions before I start hacking it up. Thanks.
Deff,. You will be Hard Pressed/ even lucky to find the wiring plug adapter for that old unit. Id cut it off and move forward on it.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on the stereo??
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
683
I am willing to trade both subs for Kicker 46CK4 wiring kit $81 on Amazon https://www.amazon.com/dp/B07NS9DTWW/?tag=caraudiocom-20 T-Spec v12...
18
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Umm the sub outputs. It's brand spanking new with an install booklet etc.
5
867
RedRyder18
CarAudio.com Newbie
RedRyder18
Virginia
RedRyder18
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
