Air space?
  • 5
3.5 is a 12.% reduction and will work though up to 10% is the usual barometer. 4 cubes is optimal an unless you absolutely cannot make it work, the GP 4 cu box is best. Keep in mind that many (most) manufacturers usually recommend subwoofer boxes that are actually on the small side as it makes the fitment more desirable. When it comes to sub enclosures, bigger is usually better within reason. This is based on longstanding applied subwoofer enclosure design; It's physics and you cannot change that.
I'm gonna go with the 4 cubic feet one
No don't apologize I totally understand and the information you provided helped alot
32
Look at the Alpine Type S subs.
19
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
I have confirmed through JL that these subs have just over 1inch xmech. As long as there is 1inch clearance in front of the front edge of the...
CarAudio.com Regular
Charlotte
    May 31, 2024
    May 24, 2024
