Is my wiring big enough?
  • 6
lliamiskool
Hi all, I am upgrading my amp! I current have a sound ordinance T B-8PTD with 10 gauge power wire, and I just bought a Urban UX-2075 (a 400W max amp) and a 250 RMS watt MTX sub. Is my existing 10 gauge wiring good enough for this amp? I don't want to draw too much current from the wire and can replace with a thicker wire if I need to, but would rather avoid it. Thanks!
30 amp fuse on the new amp and a 15 amp fuse on the SO setup. I would not recommend running mismatched subwoofers though.
The old sub was a powered enclosure. I'm reading it they are getting rid of that, and just want to keep the wire.
OP, yeah use the chart. If that's a 30 amp fuse on the amp, and the run from battery to amp is no more than 10 feet (which it's probably more), then the chart says you're good. Your new amp has more power. I would personally rather spend the $10-$20 for a 4ga run and be good.
Awesome, thanks for the replies. Yes, I’m removing the powered sub and installing a sub and amp. The fuse on the amp is 30 and the wire goes from the battery to the trunk in my 2012 Chevy sonic so I’m just about 10 feet. So it looks like if I don’t upgrade my wiring, I’m maxing it out. I’ll sleep on it
Follow up question, does anyone here know what kind of connector I need for this on my sub? Sorry I’m new at this haha.
Figured I’d ask this question here because you guys have all the answers…is there any downside to mounting my amp directly above or next to my sub? I want to mount the amp on the back of my back seat and the sun bracketed to the backseat directly next to it
Its worth the $60 bucks for upgrading your electrical. You may even have enough to do the Big3 with the 4ga left over
Yes you can use Bannana Plugs, and you can unscrew the caps and there should be a hole to run bare wire through and tighten those back down. I just use 12ga or 10ga speaker wire on those. Try to use 100% OFC rather than Tinned or CCA speaker wire.
Placing an amplifier on the back seats , I would recommend that you use at least 4 -5 washers to get the amp off the surface to get some air circulation to dissipate heat and or a couple 1/2" wood strips /one on each side under the amps mounting holes
Yes I think you’re right
Great use, thanks. But my main question was would that make the amp too close to the sub?
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
403
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
479
538
482
lliamiskool
lliamiskool
New Jersey
    May 31, 2024
    May 24, 2024
