How much is the tunning??for RF T2 subs
ViCk-BuMp
How much is the tunning for this box?
2.28 cu. ft. total
Port volume: 0.39 cu. ft.
Dimensions: 24" W x 15" D x 14.5" H
And is SUBZONE better than Q-Logic in enclosures??? oh and something else...
I have a Rockford 12" T2SUBWOOFER 2000W peak... are this dimensions good... or do I need a bigger box???
Way to high lol.
What are the port dimmensions??? That box is to small. You will need anywhere between 1.75 and 2.5 cubic feet. And 30 square inches of port area.
I recommend you spend the money and have a shop build you a box. That is an insanely loud sub and needs the proper box. A pre-fab will not cut it.
there is the subzone
12" Rectangular Vented Enclosure
11 1/8" Woofer Cutouts
Volume-2.0 cu ft airspace
Box Tuning-30 Hz
Built from 3/4" MDF
1 1/2" Front Baffle
Terminal Cup w/Gold Plated Binding Posts
Charcoal Gray Carpet
Recessed Baffle Finished in Textured Black
16" h X 22 1/4 d X 18" w
q-logic:------- Dado groove and miter joint design for ultimate strength
• 100% 5/8 in MDF construction
• Spring-loaded terminal cup with 5-way binding posts
• Easy-reference port tuning chart included
• 4 inch port can be cut for perfect tuning with easy instructions
• One-piece grill accomodates large roll surrounds
• QxE ring allows for a range of mounting diameters
• 2 cu. ft. internal volume
• Trapezoid shape better utilizes trunk space
• Includes woofer mounting screws, poly fill, speaker wire
• H 18 3/4 in x W 23 in x DT 13 in x DB 18 1/4 in
SUPPOSIBLY THESE ARE THE RIGHT BOXES FOR MY SUB
They were awesomne man. The components and Coax speakers I shoulk have kept. Theyre amps were pretty nice too. I never ran any of theyre subs...
20
891
Buck, great idea. I did that tonight, and it actually didn't wheeze like a fat guy trying to run a marathon. I am going to put two windows that...
19
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
774
If your audio system constantly draws more amperage than your alt produces, it will drain your battery, to the point of the battery needing to be...
14
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
ViCk-BuMp
ViCk-BuMp
San Diego CA
tRiGgEr
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
