Jump to content
ViCk-BuMp
How much is the tunning??for RF T2 subs
Recommended Posts
How much is the tunning for this box?
2.28 cu. ft. total
Port volume: 0.39 cu. ft.
Dimensions: 24" W x 15" D x 14.5" H
And is SUBZONE better than Q-Logic in enclosures??? oh and something else...
I have a Rockford 12" T2SUBWOOFER 2000W peak... are this dimensions good... or do I need a bigger box???
HU:Clarion VRX925VD AM/FM/DVD Changer Controller w/7" LCD Monitor
Front: 6.5 Infinity Kappa
Back: 6.5 Infinity Kappa
AMPLIFIER Hifonics BX1500D
ROCKFORD T2 (2000W)
Share this post
Link to post
Share on other sites
2.28 cu. ft. total
Is that before or after port displacement?
Also keep in mind that the calculated tuning frequency will vary slightly due to sub displacement.
Share this post
Link to post
Way to high lol.
What are the port dimmensions??? That box is to small. You will need anywhere between 1.75 and 2.5 cubic feet. And 30 square inches of port area.
I recommend you spend the money and have a shop build you a box. That is an insanely loud sub and needs the proper box. A pre-fab will not cut it.
Before poking fun at others at least learn to spell. I won't go into all the gammar mistakes!
Irony?
Your sig... Im trying to figure out if you think he spelled grammar wrong. Because, he didn't. ;) Irony indeed.
:wow:
Share this post
Link to post
it's before...
ROCKFORD T2 (2000W)
Share this post
Link to post
it's before...
Yep way to small. read above suggestion.
Irony?
:wow:
Share this post
Link to post
there is the subzone
12" Rectangular Vented Enclosure
11 1/8" Woofer Cutouts
Volume-2.0 cu ft airspace
Box Tuning-30 Hz
Built from 3/4" MDF
1 1/2" Front Baffle
Terminal Cup w/Gold Plated Binding Posts
Charcoal Gray Carpet
Recessed Baffle Finished in Textured Black
16" h X 22 1/4 d X 18" w
q-logic:------- Dado groove and miter joint design for ultimate strength
• 100% 5/8 in MDF construction
• Spring-loaded terminal cup with 5-way binding posts
• Easy-reference port tuning chart included
• 4 inch port can be cut for perfect tuning with easy instructions
• One-piece grill accomodates large roll surrounds
• QxE ring allows for a range of mounting diameters
• 2 cu. ft. internal volume
• Trapezoid shape better utilizes trunk space
• Includes woofer mounting screws, poly fill, speaker wire
• H 18 3/4 in x W 23 in x DT 13 in x DB 18 1/4 in
SUPPOSIBLY THESE ARE THE RIGHT BOXES FOR MY SUB
ROCKFORD T2 (2000W)
Share this post
Link to post
Sub zone is the better of the 2.
But I would still have a shop build it. They will custom build it to your vehicle...
Irony?
:wow:
Share this post
Link to post
And with the sub zone optimal port area will not be factored in;)
Irony?
:wow:
Share this post
Link to post
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
