what the hell is the sub displacement?
  • 4
It is the ammount of space inside the box that the sup displaces. Let's say you want a 1.0 cu.ft. box.
If you make a 1.0cu.ft. box and have a sub that displaces .1 cu.ft. You'll end up with a .9cu.ft. net....which would mess up the tune.
I think he was asking about the RE12s displacement, not what the term "sub displacment" meant. At least I hope he meant that.
Thanks guys, I appericate it. If I just use .07cu feet will it cause any problems? I dont have to be 'exact' do I?
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
424
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
272
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
421
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
280
SenateS684
SenateS684
SD
AzGrower
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
