Power HX2 Box for SQL
  • 2
Buckshot
Michigan
I plan on purchasing another power HX2 for the setup in the ol' venge, but I really don't know what the best SQL setup will be. I think I could get ~3.5cu ft, MAYBE 4 if I try real hard. I want to go with a dual ported setup, probably tuned to somewhere around 35 Hz.
How should I go about doing it? Seperate chambers tube ports? Slot ports?
a 3.5 cube box with both drivers stuffed in it and a common port?
Give me your input guys!
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
387
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
299
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
643
With 6500 rms.. you are still going to need some battery bank and/or supply for that demand
17
Buckshot
Buckshot
Michigan
ax600
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
