How do i waterproof my 6.5" speakers?
Pineapple
i just switched out my DA M661 components for DA Hex's. i noticed there were water marks on the back of the 6.5" midbass. when i mount the 6.5" in the door, there isnt anything to protect the speaker from water. so everytime it rains, my speakers will get wet. is there anyway to safely water proof them? maybe partially wrap them in plastic or make a shroud?
Buy the foam baffels, or bass boxes. And cut out the back portion. Unless you park on a slant this should protect the speaker. You could also silicon up the wire connection to be safe.
WOW, i never knew such things like this existed. exactly what i was looking for, thank you!!!!!
if i use these baffles, itll wrap around the entire back portion of the speaker, would this affect the sound quality of the 6.5" speakers? doesnt the 6.5" midrange/midbass need an open back area to perform right?
The vast majority of speakers are created with an infinite baffle (free air) setup in mind. Some say that the use of a foam baffle, acting somewhat like a very small, sealed eclosure, actually improved the midrange/bass response. But this depends on your install & speakers, YMMV. If you liked the sound they created before the baffles, you could always cut out the backs like stated above. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
what does YMMV mean? doesnt the 6.5" speaker need open air to function correctly? i notice on my diamond components, there a whole on the back of the magnet and a mesh screen deep inside.
YMMV = Your mileage may vary & no it doesn't need open air to function correctly. If this was the case anyone who has their speakers in kick panels or fiberglassed in their door panels would not be very pleased.
Some speakers are designed to perform best infinite baffle (no box). Some speakers will still perform decently well in an enclosure. If you are really that worried about it, just cut a large hole in the bottom of the baffle; Viola, you're back to being infinite baffle with the speakers.
It is possible to put the speakers in kickpanels and end up with undesireable results //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Just depends on the speaker being used. Some speakers will need to be vented into and open area (like into the inner fender well) when in kicks to perform optimally
note. as cj said
cut a hole in the back of the foam
DO NOT cut a hole in the 'back'
rain is falling from above, so like squeak said, cut a hole BELOW the magnet on the back side... like this VVV
and for future refrence squeak... im not a photoshop queen //content.invisioncic.com/y282845/emoticons/bawling.gif.6287aa5d1d447c8af063fc9466e822ef.gif so please dont put that in your sig or call me that... it makes me cry.
you better //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
dont you love my idiotic photoshop skills?
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
231
It may be that they act like this because they are underpowered and the push to play them louder is causing the amp to clip the signal, which will...
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
175
Pineapple
Pineapple
San Jose, CA
Berry47
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
Latest topics
