Factory ground for Alpine 9833
No. Disconnect that wire ASAP - Mines blew up wiring it like that.
J/K . Its fine - Nothing should go wrong with wiring it that way.
geez scared for a second... i cant read that fast! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
831
1200mk
1200mk
Los Angeles, CA
1200mk
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
