What are some of the best 2-way comp's
You must have alot of cash, I am not farmiliar with the d9 line and I don't think the d5600.4 will be enough power. I think you would be good with a ppi pcx2125, that would run these very nice.
Thanks for the recomendation...I am going to go and check that amp out right now. The reason I have a good amount of money to spend on my system is because I originally saved enough to do comp's and subs...but now I have decided not to do subs b/c I need the trunk space for now.
-Matt
that will be more that enough power.
Cause if you buy a 2 channel amp(most amps) you will find the only put out half of the power at 4 ohms as they do at 2 ohms. Check the specs on any amp other than jl's or possibly a couple others and you will see there is a big difference. So therefore if you buy the 2 ohm verison your amp would be smaller. For example have a ppi pcx2200 which does 2x200 @ 4ohms, 2x400 @ 2ohms, and 800x1 @ 4ohms bridged.
Boston Acoustics Z6 are phenominal, along with what 3.5Max mentioned.
Also, look into horns //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Image Dynamics and USD Audio.
581
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
880
mkell
mkell
STL
outbacksport
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
