somethings fishy...
Boosted92HB
I just plugged in some #s on a port calculator and...
box is 8 ft.^3
2 RE SE 15's
ported to 35Hz...
4x16.75 port
Now here comes the weird thing...
It tells me that I only need ~12" of port length. Is this correct? seems like everyone here is running some 20+ inch long ports while still being tuned in the mid 30's. Is this setup more along the lines of SPL than SQ? Im going for about a 50/50 mix of the two...
Your calcs are correct. You only need a 12" long port because your box volume is so high. As box volume increases, port length decreases, and as port cross sectional area decreases, port length decreases. However, as you decrease your port cross sectional area, you run the risk of port noise.
Hey Simos, you think you could PLEASE tell us how to input the port calc formula into Excel? I'd be very greatful! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Thanks a bunch!
I attached the excel file I put together as a zip file. Not sure if it will work to attach it as a zip file or not. It should be fairly self explanatory as to what you need to do. The cells that are highlighted red contain formulas, so dont type any values in. The cells highlighted green require a value.
port calc.zip
  • port calc.zip
It is not 100% accurate but fairly close. I recommend doing it by hand or on the computers sientific calculator.
Boosted92HB
Boosted92HB
Albany, GA
Simos
1aespinoza
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
Latest topics
