How would I wire up my PS2 into my truck?
you need a DC to AC power inverter. you can get these at pep boys, wal-mart, just about anywhere. im not sure what the power requirements are on the PS2 but yu should be able to get away with a 100W one. This just plugs into your 12 cigarette/accessory plug, or if you wish you can wire it up to any other 12v power source. I'd also look for an inverter that has an on/off switch. as far as connecting audio video well thats pretty straightforward. if you have an aftermarket headunit then plug the RCA audio outputs to the auxilliary inputs on your headunit. If you are rolling stock then *shudder* you will have to use a FM-Modulator. Im not particularly a fan of thesedue to SQ, and reliability issues. But go with whatever you need. As far as video, well it appears you dont have a flip-out LCD headunit with a video input, so you will need a LCD monitor, or a small CRT TV if you want to do it that way. If you go with a CRT (regular tube style TV) then you might want to consider a higher powered inverter (say around 300-400 watts). Then connect the S-Video or RCA Video cable to the inputs of the display (CRT or LCD) and you are good to go. Also, consider wireless controllers, or buying extension cables for the controllers and flush mounting the ports into the center console, or something cool like that, so that you can mount the PS2 out of sight.
Hope it all works out for you. BTW took a look at your charger. Dont put underbody neons on it....
i was also thinking of putting my playstation in my car, i already have a power inverter and my playstation would hide underneath my seat with it. I just wouldn't want to run wires directly to my lcd screen because my wires from the playstation aren't long enough to connect to my tv.how do you go about connecting the wires from the playstation to the tv.
get a RCA composite video extension cable down at the 'shack.
go with whatever distance you need. they are usually sold in 3,6,12,20ft lengths. make sure it has one female and one male end.
Yea i was thinkin bout gettin a 20" LCD flip down somewhere in the back. Then I could hide the PS2 back there and have it ready to go.
supraman1379
Lifted 03 HEMI
supraman1379
Ocala, Fl
supraman1379
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
