will EV's destroy the aftermarket car audio industry?
  • 2
audioholic
not a moderator
I haven't been paying much attention to car audio lately, so I apologize if this is already a well versed topic. But I've been wondering, how will electric vehicles affect the car audio industry? We will no longer have a mechanical alternator driven from a gas powered energy source, our amplifiers and sound processors will draw directly from the vehicle's main power storage, and given a decent sized system with a decent electrical draw, would affect the actual range of the car.
But its also technically true that spinning an alternator (or multiple alts) also burns more fuel and decreases range on internal combustion vehicles. I suppose once we have fast-charge batteries (such as graphene based) that this will be less of an issue. But Im curious what people think on how, or if, EV's will affect car audio.
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
585
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
899
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
691
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
audioholic
not a moderator
audioholic
Parts Unknown
audioholic
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
