Replace Dash Tweeters on 2013 Sienna: Good idea?
  • 2
whatwillhappenif
I love music, but have a very limited background in electronics.  Mostly I've installed a car stereo receiver and replaced some caps in my home speakers.
We have a 2013 Sienna LE with the stock 6 speaker stereo.  It sounds pretty good overall, though a bit muddy.  I figured the cheapest and easiest improvement would be to replace the 3 1/2" dash speakers with an inexpensive ($15-30/pair) tweeters such as the coaxial Pyle PLG3.2 ($15) or Pioneer TS-A878 ($34).
1) Do you believe these installs  will improve the car's sound?
2) Because these speakers are co-axial and, thus, have a crossover built in, will they work with, as I understand it, the factory stock serial wiring of the dash tweeter and door woofer or do I need to install a crossover?
3) An aside question,  because the current  speakers are apparently wired in serial, does this likely mean the factory speakers are 2 Ohm speakers (2 + 2 = 4 Ohm total) rather than 4 Ohm (4 + 4 = 8 Ohm total)?
Much obliged.
Much obliged.
they will make the speakers sound considerably worse, you lose all bass and will sound tinny. Never swap speakers unless you have the foundations which include amplification power, head unit processing, acoustical deadening already done and never swap out to bottom of the barrel garbage speakers that you shouldnt touch even with a ten foot pole.
What you want to do is a head unit swap. Your stock speakers will sound massively different with more power and better processing than your stock head unit has.
Thanks for the response.  Can you explain why I'd lose all bass if I installed these in serial with the door woofers?
thats my bad i thought you were going to replace the doors as well. You definitely just want to replace the head unit over popping in cheap dash speakers. Plus you need proper crossover capabilities as well for it to have any sort of blend with the door speakers.  Overall leave it as is and Get a proper head unit to them and they will shine.
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
577
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
You don't have to but with the exception of what is usually high end car audio companies and home audio drivers it can be hard to find just the...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
whatwillhappenif
whatwillhappenif
Jeffdachef
Random4thGuy
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
