One sub with limited space under truck seat
  • 4
Smallz
CarAudio.com Newbie
7
So, like others, I've been out of the scene for 10+ years and looking to dip my toes in again. I've been doing a lot of reading the last few days, but dang it's hard to get up to speed on what I should try.
I've got a '13 Ram 1500 and looking for an improvement over the stock 6"woofer that's currently in there. Right now I'm just looking for one sub for under my rear passenger side seat, so thinking box would be less than 1cuft.
I don't have an amp (except for a 15 year old earthquake D2), so would be looking for that after deciding on the sub.
From the research I've done, I'm somewhat leaning towards the SSA F8L 8" or Sundown SA10, but I'm open to other records recos. Probably sealed because of my space limitation, but again open. I listen to a wide variety, but mostly rock/classic rock with a fair amount of rap and pop (and of course Disney 😀). Just want something that sounds good with more low end! Thanks in advance.
A single 8 sealed in a pickup is equivalent to screaming into a pillow. You are setting yourself up for failure.
Ok, I get your thinking on that. But I was looking at the F8L because it seems that the ported box requirement is small enough that I could fit one in. Any 10" though would most likely need to be sealed. So maybe the better question is a ported 8" or sealed 10"?
8 or 6.5 ported with port firing to the side door. a sealed 10 wont give you anything.
Sure you have room for a F8L? You'll need 8-9 inches under you seat. Sub has a mounting depth of 6.5".
It will definitely be tight. But I have right at 9 inches now to the bottom of the seat. Could probably get another half inch by cutting the carpet and, if I really needed to, lifting the seat by an inch. It might also just be that it's turned down when someone is riding back there and the seat is up when it's just me, which is most of the time.
Any other suggestions for a good 8"sub that could work in a ~0.5 cuft ported box?
If you have about nine inches I would raise the seat an inch and run the F8L.
Thanks for the feedback. I think I'm going to give it a try.
Could anyone help with ports (or should I post again)? If I go with the 0.55 cubes@ 31Hz that it's specs call for, and I wanted to use a 3" aeroport, how long would it need to be? I could maybe squeeze a 4" port but will have to see.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
446
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
4
292
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
441
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
296
Smallz
CarAudio.com Newbie
Smallz
Smallz
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
