Jump to content
Sign in to follow this
Bjfox1970
Classic OEM headunit into new amplifier
Recommended Posts
I have a ‘72 Delta 88 convertible.
i am wanting to keep the OEM AM/FM stereo head unit, but run the high level outputs into a modern Bluetooth amp.  The original head unit has common ground outputs and requires 10 ohm speakers.
I plan on installing modern 4 ohm speakers and powering them with the modern amp. Obviously this system uses floating grounds for the speakers. The amp also requires floating ground high level inputs from a head unit if one is used.  I found a floating ground adapter, however it is designed to use a floating ground head unit with common ground speaker wiring.
Two questions:
Would it penpossile to just split the common ground output to both input channels on the amp?
And if not:
Is it possible to use the available floating to common ground adapter in reverse?
Share this post
Link to post
Share on other sites
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
