Help choosing which amp
  • 2
I would hook up each one and run around with it for a week then let your ears decide which one is louder, so long as your gain is set correctly. On paper doesn't mean jack **** vs in the car and in the actual real world playing.
Not at all, amplifiers have gain control to attenuate the output to safe levels.
I've moved this post to installations. Can't work out how to delete it here.
well, thats kind of an open ended question....., you can do 2500rms@1ohm, or you can do a pair of 1k-1200rms@2ohms. just have to know the amp...
If you're shopping in the 10 cents per watt and under department you should probably expect dubious designs and third world build quality from...
17
kingjd7
kingjd7
Kent Ohio
Boomin_tahoe
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
