Help choosing which amp
  • 2
I would hook up each one and run around with it for a week then let your ears decide which one is louder, so long as your gain is set correctly. On paper doesn't mean jack **** vs in the car and in the actual real world playing.
Not at all, amplifiers have gain control to attenuate the output to safe levels.
6
I've moved this post to installations. Can't work out how to delete it here.
well, thats kind of an open ended question....., you can do 2500rms@1ohm, or you can do a pair of 1k-1200rms@2ohms. just have to know the amp...
5
If you're shopping in the 10 cents per watt and under department you should probably expect dubious designs and third world build quality from...
17
kingjd7
kingjd7
Kent Ohio
Boomin_tahoe
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
