Midbass in back, coax in front?
  • 5
kcr357
ft laud
Doable or dumb idea?
My plans were to run silver flutes in the back playing from 50-150ish hz, then some coaxs from 150 up.  Not using a sub, just looking for really tight and loud kick drum freq and ear splitting vocals/guitar
Definitely components up front to provide you better imaging and staging.  The rears, go for 6x9's but place them very study with at least 1/2 inch (3/4) is better to get a better mid-bass kick and ensure your trunk area has some sound deadening as well to stop any unwanted rattles.  Power them all with a 50rms x 4 channel amp and you will be happy.  Oh, don't forget to apply sound deadening to front doors before you install the components up front.
Also when choosing your 6x9's check if they have at least 1.5 inch voice coil or larger so they can handle some power, at least 100rms each, again, more is better! :fro:
Dayton Audio GF180-4 6-1/2" Glass Fiber Cone Woofer 4 Ohm (parts-express.com) I have eight of these going in the car. 2 per door. Great little...
Sealed midbass pods are awesome if you can fit them. I don't nessecarily see the need for an 8" midbass, but then again I'm running a very large...
15
Im not sure if this helps or is the correct way but I have 6.5 mids in the front doors and tweets in the pillars I used 2way 6x9s in the rear...
972
kcr357
kcr357
ft laud
DRBOOM
Bobbytwonames
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
