chadwilliam1
Ok I am having some a pillars made with a 3" componet set, i am considering going active with them and not buying the crossover. I need help deciding on my best option.
2016 chrysler 200s with a kenwood 10 channel DSP. 6x75watts rms and 4 aux out. I have i have 8 channels in the car plus the subs and if I go active I will need 10 channels. So a pillars need 4 channels, front doors 2 channels, rear doors 2 channels and rear deck 2 channels. Plus subs. I have a 4 channel kenwood amp. I would like to use this amp for the a pillars. i have full ex and time alighnment on my DSP.
My question is will it work if I split my aux output on my dsp going in to the 4 channel amp to run the front mid and tweeter? The 4 channel has a HPF and a LPF. So on the dsp amp channels 1-6 controll the rear deck, rear doors and front door. The 4 channel amp control a 3" mid and tweeter. Or is there an amp that will do this like the kicker key?
Here are the amps i own.
Kenwood DSP XR600-6DSP
Kenwood 4 channel amp KAC-M3004
