Alternator intermittently charging?
Ven0m
CarAudio.com Recruit
39
My battery recently took a ****, so i went out and purchased a Optima Yellowtop which is apparently supposed to read 13.1v fully charged however ive never seen it go over 12.8v. I ran a voltmeter into the car and noticed that while driving sometimes the voltage drops from 14.5v to 12.5-8v and then maybe 10 minutes later it will go back to 14.5v this really has me stumped and i really dont want to damage my new battery. Bad Alternator? No lights on dash or anything
Check your owners manual. I don't know much about alternators, but I know in my 2007 Yukon, the owners manual says the alternator will do this based on things like power demands, battery voltage, temps, etc.
I have an 09 Saturn Aura, both GM cars.. ill have to look into it. did you find a way to bypass the system to have the alt run at 14.5 all the time in your Yukon?
No way to make it run 14.5 all the time. That is just not possible, only option would be to do a Big 3 upgrade and upgrade the cars alternator with a bigger unit in order to make sure you don't experience as bad of a drop.
If you're referring to a drop in charging voltage, I doubt the big 3 upgrade would help. Mine only had the factory Bose system in it, but even without any major power consumption voltage would still dip well below 13V regularly. From my understanding, it's supposed to do this at times and sounds like it was to help protect the battery from excessive wear and possibly help with fuel mileage, but don't quote me on that. The manual didn't give a lot of specifics.
If you're talking about a voltage drop from a big bass hit, then I would agree the big 3 update may help, depending on how much power the system is using.
i dont experience that big of a drop on the bass hits, im just worried about charging voltage as i do not usually travel that far in this vehicle and last weekend i went on a 1.5hr trip and battery just barely had enough juice to get the car started when we got back home (clicked a few times and cranked really slow). I thought the alternator was going bad but it seemed fine on a voltmeter so we went with a new battery. I wonder if its not getting a positive charge on longer trips due to the lowered voltage and taxing sound system.
also, how would my battery ever reach its full charge of 13.1v if the alternator is usually at 12.8? lol
12.5V is the normal resting voltage when fully charged, so that's about right. Charging voltage is higher because the charging source (alternator) must be higher to allow the current to flow. It's like trying to fill a bucket of water from another bucket via a hose. If the filled bucket is higher than the empty one, water will flow you the empty one. If they are at the same level, water will fill the empty one until both are equal. You can think of the height difference as the voltage difference between the alternator and battery. If the alternator charged only to 12.5 V, the battery would never reach its full charge, just as if those two buckets were on the same level.
I haven't used an Optima since the early 2000's. If they are designed to run at 13.1V, I'm not sure if it will be possible to get it there without some extensive work. Maybe others can let you know if 12.5-12.8V is ok with it, but I'd also check with Optima themselves for an official answer. It could just be a moot point if things are working fine and they are ok with it in these variable charging systems.
Ok thanks for your help, i wonder if theres a way to set resting voltage to 13.2 in an ecu tune or something. oh well it is what it is i guess.
I doubt it, its probably controlled by one of the many BCM's in cars these days. The ECU only controls fuel and spark.
Optima batteries are garbage anyway, and way overpriced. Google search if you wanna know why. This has been discussed/brought up many times.
You might have a PCM which will need to be disabled to receive the full voltage stability from the alt. OR....you have a lose connection somewhere causing your issue.
Doesn't know much but replies anyway lol.
Owners manual isn't gonna help any btw.
I found out about this possibility BECAUSE of my owners manual. I made it clear that this was only one possibility and turns out he owns a GM vehicle as well, making my first reply even more valid. So why not knock it off before you dig that hole deeper?
Dig that hole deeper? Well he is right in all honesty a owners manual doesn't really tell you squat about a vehicle.  And as I said before doing a Big 3 upgrade and going to a bigger alternator & a battery in the rear is going to help stop some of the voltage drops even without a big bass hit as it will keep the battery at fully charged and with said bigger alternator it will put out more of a load overall. Also an alternator doesn't doesn't have squat to do with mileage, idk where you would come up with that but no just no, but hey what do I know I'm only ASE certified in multiple areas my dad was only a machinist for close to 40 some years and only been through several schools as well like him but w/e.
AND yes optima batteries are complete garbage and vastly overpriced.
One of the better batters out there shockingly is the Ever Start Plus Battery. And FYI people there is only 4-6 battery companies through the ENTIRE world! Everyone thinks that each battery name is owned separately and that is just not true. It is like buying a refurbished stuff in auto parts there is only iirc 4 companies that refurbish auto parts and what they do is just slap a different sticker on the box. The other difference is yes some have better quality parts put back into them and the length of the warranties and that is all. Trust me on this, between the mechanic stuff I did I was also parts manager at a few different big name auto parts and diesel truck parts companies and saw said factories myself.
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
503
I don't have one...but I check my voltage with a dmm once a week or so
12
653
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
What the ****? Are you trying to put ohm's law into very complicated verbiage?
6
944
Ven0m
Ven0m
Halo209
Bobbytwonames
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
