Adding a battery for dummies (me)
  • 6
I was about to ask the same thing. I received my 1/0 Gauge wire today and my battery tomorrow. Guess i need to order some fuses for 1/0 as ill be using 4ga for now with my amp. Im doing this so when i upgrade subs and amp it will already be done. Do you recommend running the wire under the car for this?
639
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
600
Thanks. That makes sense. It sounds pretty good as is.
852
Jeremy11
Jeremy11
Loganville,GA
fithwheel
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
