Jump to content
Sign in to follow this
Jeremy11
Adding a battery for dummies (me)
Recommended Posts
Well so as the title says. What is the best/proper way to add a second battery in the trunk? Any wiring diagrams and instructions or tips would be greatly appreciated. Please let he know of any info needed.
Thanks
Jeremy
Share this post
Link to post
Share on other sites
Positive from front battery to rear battery positive. Ground rear battery to frame.
Fuse the power wire at BOTH batteries.
2016 Focus ST3 - Rockford DSR1 / PPI 900.4 / Silverflute 6.5" mids / Massive CT2 tweeters /Sundown Xv2 15"/ Taramps DSP3k / Stinger Roadkill / KNU wiring / Northstar SMSAGM80 /
2010 Focus coupe 157@46hz
Pioneer 80prs /(8) FU Audio 750 12"s / (4) FSD 2600s / (1) FSD 125.4 / (1) FSD 85.4 / (4) Crescendo UN-10" mids / (4) Crescendo FT1 tweeters / Stinger Roadkill / 2/0 EB flex wire / (5) Powerware 90AH batteries / DC 270XP Alt /
https://www.youtube.com/popwarhomie
too many freq at once, burn the coil, we all know, over 40-50hz, its all coilburning material.
Share this post
Link to post
fuses are for wussies
My wife doesn’t know about my car audio addiction...shhhh
Share this post
Link to post
Until you get in a wreck and your fender pinches your power wire and catches the car on fire.
Edited by Popwarhomie
Share this post
Link to post
So thats it? And just wire the amps off the second one? Now I'm not doing a super spl system probably 4k watts total,  what type of batteries should I use?
Share this post
Link to post
Yes.
Depends on budget. Can’t beat lithium. Yinlong or headway cells are fairly priced.
Share this post
Link to post
i'd do a dedicated pos and negative run to the rear personally.
09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
Headunit: Pioneer 80PRS......Mids/Highs two pioneer gm 8604 bridged, one at 4 ohms bridged one at 2 ohms bridged, one ppi 600.2 for tweets.
Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
Share this post
Link to post
I was about to ask the same thing. I received my 1/0 Gauge wire today and my battery tomorrow. Guess i need to order some fuses for 1/0 as ill be using 4ga for now with my amp. Im doing this so when i upgrade subs and amp it will already be done. Do you recommend running the wire under the car for this?
Share this post
Link to post
For my cars I always run the wire inside. For my trucks with actual frames I run them outside along the frame and through a grommet on the bottom of the cab.
Share this post
Link to post
Both off of the upfront battery?
Share this post
Link to post
yeah if you have an upgraded dedicated alt to front battery pos and ground as well.
Edited by Jeffdachef
Share this post
Link to post
What Amp Fuse would you recommend from the Positive and Is a Mega Fuse ok?
Share this post
Link to post
an ANL fuse
Here's a 420 fuse sale, you can choose whatever fuse you want. 4 of them for 20 bucks... 420 lol.
https://gpcaraudio.com/420-sale-4-for-20-gp-anl-fuse-block-fuse/
Share this post
Link to post
Best to use sky high wire with those 420 fuses
2006 ridgeline hu:KW ddx9903s morel 5.25 maximo comps 6.5 maximo coaxial 2 Dayton ultimax 8s 1.65 @35 amp Rf t1000x5ab
work truck 2017 international pro star Alpine ute62 hu. Amps RF t1000.5ad 4 ch mode infinity k1000  sa 15 3.5 @ 30hz or 2 type s12 6.3 @ 41 hz  or jbl s3 2.0 36hz. or nvx  vcw 10 1.1 @ 32hz  2 8 " eminence pro woofers. 2" Dayton rs52fn midrange. 1 1/8 Dayton dc28f silk dome tweeters.
Share this post
Link to post
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
