Please help!
Chipdip
So lately my amp/sub has been acting up. Sometimes it plays fine but most of the time it wont. Unlesss I press down on the gain adjustment! Then it plays like normal. Wtf... Any ideas guys? I redid my ground just to make sure and I'm getting 12v on the remote and power lines. Havent dug any deaper then that.
It looks like normal operation. It still has a blue light on and is reading at 12v. The dub just doesnt make any noise. When I turn the nob on the bass adjust by my dash you can see the sub move but thats it
843
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
850
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Chipdip
Chipdip
tonksie93
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
