Need amp recommendations
  • 4
J.sche
I got an Orion HCCA 12. Dual 4 ohm so I can only run it at 2 ohms. I'm looking for a decent amp for around $250. Would like to run between 1500 and 2000 watts at 2 ohms. Yes I am running on a stock 125a alternator. I do have a 110ah to run with it though. I'm not gonna beat the piss out of it if I'm not reliably able to.
I mean I can go a little more. I'm mainly looking for used amps cause I know my price range is a smidge tight
I just seen the md1800 2 ohm do almost 2500 certified at 2 ohms. Are taramps really that good? I know a few years ago I never really heard anything good about them (nothing bad either)
I've had 10 of them and love them. Never had a single problem with them.  I would spend the $30 more and get the MD 3000 over the MD 1800.
349
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
859
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
J.sche
J.sche
J.sche
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
