Blew subwoofer - replaced it - still not getting any bass
  • 6
lobsterback46
Hi everyone,
I was dumb and blew my subwoofer...listening too loud too long.
My symptom was the base getting cut out of the music for a bit and then coming back, until it never came back. It was an old JL 10w V1. I just replaced it with the same model(but newer) and hooked everything up but I am not getting any bass.
I have a JL audio Slash 500v2 as my amp. Do I need to reset a fuse on the amp? Have I damaged the amp too?
Any help would be great.
Thanks!
1st thing I read was too loud too long, IF the gain was properly set, it wouldn't happen.
Does the LED light come on on the amp at all? Check fuse going to amp or on side amp itself.
Would suggest you take the following steps:
  • check if your amp lights up or not in protection mode;  If it is, then chances are, you have fried the amp or may need fixing; :blackeye:
  • check speaker output connection on the amplifier to the subwoofers;
  • check RCA connection to the amp is secure;
  • check power, ground, remote wire;
  • With adding a new subwoofer, you will need to re-adjust your amp to suit your subwoofer so you don't drive it into clipping;
  • check your new subwoofer with multimeter so its not faulty or has a dead voice coil in between.
  • If you have access to another amp, replace your current amp to see if the problem remains;
  • Hopefully troubleshooting with the above suggestions may remedy your issue.
  • Let us know how you go mate! :graduate:
Is the sub 4ohm?
the amp is 500watt rms @ 1.5ohms
in the manual it says if you run 4ohms the amps rms is 250, if the sub is 500rms you've more than likely blew the amp
Is the sub 4ohm?
Ok I have to say something now after reading your stupid comments/posts.
I'd love to know how you can blow an amp before the sub, esp since you know very little on what happened in his situation. Please don't reply with guesses....it makes you even dumber.
Hmm.. No Bueno. Id prob be looking at another set of subs to be honest. Like some American Bass DX series. Great subs for the $. Maybe even look...
629
Thanks for all the help guys I'm going to buy a new sub, looking at some of the suggestions u guys gave. I have a small sealed box now but will...
41
4K
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
213
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
lobsterback46
lobsterback46
fithwheel
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
