DUAL subwoofer setup. one sub makes a weird ticking sound?
realflow100
CarAudio.com Recruit
62
one sub is making a ticking sound only when its moving inward and its definitely not coil rub for sure its not tinsel lead noise either
if I push on it with my hand it doesnt feel scratchy or anything it feels identical to my other sub its just making a weird ticking noise at low to high excursion.
it doesnt get any louder the louder I play it. it just changes with the frequency the sub is getting. its not very loud but its annoying at low-medium volume it sounds like its a tiny piece of plastic tapping on something inside the dust cap but theres nothing I can see anywhere around the spider or voice coil making any noise I dont know how to get rid of it. I tried running it free air at high excursion for a while but it barely made a difference it still does it. its really weird
its done this since I got it out of the box. other than that the subs both hit hard and deep and sound good but the ticking noise is really annoying. its not air leak because it does it free air as well.
I'm not going to blow my subwoofer by doing something stupid like that. and I dont want to risk starting a fire either. my room has carpet.
Ok, if the subwoofer sounds ok when it travels , I suggest you take the subwoofer out and test with a multimeter, it may have a faulty voice coil. Another method would be to test the same subwoofer with another amplifier to see if the ticking sound persists,  if not, then it could be your amplifier as well.
Usually speakers will work fine and sometimes the amps fail and can cause issues.  All the speaker does is convert electrical energy to acoustic energy and nothing more. :fro:
the coil measures fine. it doesnt behave weird other than the ticking noise.
the amp is working fine too. powers my other sub just fine on the same channel.
if I move the cone in and out by hand i can hear the ticking only when the sub is moving inward. it doesnt get louder the louder I play the sub. once the ticking sound happens it's just audible but doesnt get louder the louder i play it. the sub can be reaching close to maximum excursion and the ticking sound isnt any louder than at low excursion. it doesnt sound anything like coil rub at all.
if i press on the spider in a certain spot it stops for a moment then comes back
ive measured the subs they are reading exactly the same.
it sounds like its in one spot of the spider like a chunk of glue is stuck underneath it or something weird right near the voice coil and then the suspension stretches downward it makes a noise as the glue separates and touches the spider again??
but its not coming from the coil or very edge of the coil where it attaches to the spider. its coming from somewhere in the middle of the spider between inner and outer edges of the spider in one specific spot. i tried pinching the spider all along the different ribs/waves around that area and it helped a tiny bit but its still doing it.
I am trying to save up money. I plan on getting a much better box and better subs with the new box tuned to around 30hz or so.
it sounds like glue thats dry but has tackyness to it and its being "unsticked" repeatedly.
nope Ive felt all around the spider.
 its a single spider. and the spider venting is too small to get even a finger through. but its definitely on there all the way around. not loose anywhere. its glued on good all the way around and around the coil too it stops if i press my finger on a certain spot on the spider but that doesnt help anything because i cant just hold my finger there all the time. and its hard to find the exact spot since it seems to be a big area where I can put my finger on the spider and the noise stops but its nearer to the coil than the outer edge of the spider
Im pretty sure it would instantly break if i did that. it probably just make a sharp loud pop noise and be dead within a half a second.
and I dont want to deal with the smell that would make.
Might launch a YouTube career if you do it and make a vid...  lol... probably get a few hits.
Just title it "Terminator Extermination"
Just a thought Op
Considering the history of it all I'd say it's a safe bet they're about as close as you can get to already being exterminated. Op just doesn't realize how bad of a shape they're in.  I'd put a little  $ on it anyway lol....
The Biden administration on Tuesday backed down on a controversial proposal to direct the IRS to collect additional data on every bank account...
31
5K
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
695
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
703
realflow100
realflow100
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
Latest topics
