hcca 8000.1dv2 proper fusing help
  • Thread starter Starkillers2019
  • Start date
  • Replies 11
  • Views 3K
  • 5
S
Starkillers2019
Guest
got the amp .....theres 2 runs into the unit   they recommend  900 amp fusing      would 2 runs with a 450 amp fuse work      these would be real short runs maybe 3 feet max   with 1/0  gauge wire.          or should i quad the 1/0 gauge wire and have 4 runs of 225 anl fusing   into  double    2 x 1/0 into 1 1/0 connectors.         not to much info on subject..    any help would be great     so  i can buy all the fusing and holders.        thank u for any help u can give
Want advice now?
I quote you in that other thread...
"lol  your funny   i have a high output alternator   actual one is pictured here , 4 batteries  , i dont need to tell you these details  ..     im just looking to build a box   and got a lecture about sealed isnt good..lmao           forget i asked you guys..  i know now never to ask for help here again..    its fine with me i got my box designs through email direct from orion audio... see ya later      and its a adjustable box.    sealed and ported"
Then this nugget...
"went with ported...  sorry sealed ...lol"
Why ask for advice if you're just going to do whatever you are bent on doing anyways.
You cannot split loads like that and expect not to blow every fuse every time. Electricity takes the path of least resistance (it's futile to argue) and therefore will try to flow through all at once and blow them all.
You only need one fuse per main wire, under the hood. Anything else is an amperage leak waiting to happen.
Want advice now?
Then this nugget...
dont want your advice .    got it  ..  now your just trolling ...   anyone else is fine..
thank you for great advice.
until it all goes up in smoke .  lol
No. A fuse hardly will help. The wire is still live on one end. A fuse would only cut off power to the other side of the fuse. If a amp is gunna blow its gunna blow. A fuse isn’t going to safe it. I’ve had amps burn up with fuses.  Fuses are a weak point. Why spend hundreds on thick wire and put a cheap $3 fuse in the way. Makes ZERO SENSE
Of course the wire is live on the battery side, but it cant contact the frame if the fuse blows. When youre running high current and say somehow the amp shorts to ground, the insulation will melt and then welcome to hell.
Want advice now?
Then this nugget...
  Yawn   🖕🏻
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
625
I ran the Orion for about a year, then I bought the Taramps when I though the Orion broke. I found a knick in the Orion bass knob that was causing...
Ive had to install a 40 amp relay on the remote due to Popping issues on one my older Eclipse HUs, That ended up solving my popping issue. One...
Guest
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
