Adding lowpass filter
  • 4
Weeboy1
CarAudio.com Newbie
I have 2 mmats 601.8 midrange speakers running in parallel and bridged off the amp.
i want to add a low pass filter or filters inline. My question is because the speakers are in parallel and amp seeing a 4 ohm load do I just need one 4 ohm filter wired inline after the amp before the first speaker. Or do I need 2 -8 ohm filters inline at each speaker.
thanks for the help
ken ,Canada
1 4ohm. I would imagine you're trying to create a bandpass by using the high pass crossover in the hu or amplifier and adding a low pass passive crossover? I use the dayton filters from parts express myself
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
640
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
5
601
Thanks. That makes sense. It sounds pretty good as is.
852
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
6
Weeboy1
CarAudio.com Newbie
Weeboy1
keep_hope_alive
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
