Rough sketchup need to find port length
  • 4
strobe
CarAudio.com Regular
126
38
Sugon
Last post got long & off topic, so starting fresh with a design to run with. Since I value my cargo space, I decided I can come up with the most space if I go with a wide, shallow upfiring design with an aero port facing the rear. This will let me throw a grill over the sub to stack gear on top. I've gone ahead & done a rough design in sketchup, but I still need to figure out port size & its displacement once said & done.
Is there any downfall to having a shallow enclosure ported like this?
Vehicle : 09 mazda 3
Location in the vehicle: behind rear seats, flat on hatch floor
Space available (Length x Width x Height):
  • Length 20
  • width 25
  • height 10
Subwoofer make and model: Alpine SWS-12d4
  • qms - 9.43
  • qes .6
  • qts .57
  • fs 34hz
  • xmax 15mm
Subwoofer Size: 12
Number of Subwoofers: 1
Type of Port (Kerfed, Slot, Aero, etc.): Aero preferred I think, open to suggestion
What type of music do you like?: All styles of electronic - from deep extended low notes, drum & bass, electro/dubstep, & chilled instrunmentals.
Is your goal SPL or Everyday Music?: Everyday music
Tuning Freq (Hz): 32-35? I want to get low but not at the expense of responsiveness & SQ (old pre fab ported sounded muddy)
Volume : Factory recommended is 1.67ft gross 1.4ft^3 net. Proposed design should be around 2.2+ gross
The dimensions you have give you 2.26cf gross volume. Subtracting sub and port displacement gets it closer to about 2cf net. With a 4 inch round port, you would need about 14-16 inches of port length to get the tune where you want it.
I would add bracing to that box as well.
Start with 2.26cf minus .11cf (approx) for port disp, .09-.1cf for sub disp and .04-.05cf for bracing, that yields 2cf. A 4x14 port makes a tune of about 32hz. Add more length for a lower tune, subtract length for a higher tune. 32-33hz would be good for your listening perferences.
Update: I went with different dimensions but ended with 2ft^3 after all displacements & bracing. Will be sub up port back. Just have to add two more pieces & do some sanding on port exit to round things over tomorrow when the glue/adhesives cure
Yea had access to a biscuit joiner so figured they'd help out. Spraying the box down with bed liner now will test it out tonight
Looks good
Are you joining the panels with biscuits?
What do you think about the sub sitting right over the top of the port opening? He may have enough room to squeeze it in there to the left of the brace idk. Hard to tell from pic..
Oh you have it together now I see
The hole is cut already. I'll post a pic when it's all put together tonight
The sub over the port will be ok, they dont look too close together, what i don't like is that wide brace sitting on top of the port, it will restrict airflow in the box.
You should prime with a shellac based primer like BIN so the top coat doesn't soak in.
The brace there is only 3/4 x 1.5" and I did sand over the edges. Didn't think it'd make too much of a difference, though it can be removed & I could pick up a dowel to glue in elsewhere.
I've already started spraying. Going to need another can though which is probably because a bit soaked in like you mentioned... oh well lesson learned. Off to buy another can & finish it up now
Whats up with the brace piece I circled?
Oh that one... yea that's glued & screwed twice on the bottom & top w/ the pvc fitted through with liquid nails. I suppose I could put a hole saw to it in the largest part there. I didn't want to cut it too short on the sides of the PVC hole in fear of the mdf falling apart
Signal flow should be HU to DSP to amps. You would lose the ability to EQ and time align the sub with the DSP unit if you bypassed the DSP.
386
383
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
strobe
strobe
Sugon
THATpurpleKUSH
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
