Jump to content
Sign in to follow this
gen1ms3
Rough sketchup need to find port length
Recommended Posts
Last post got long & off topic, so starting fresh with a design to run with. Since I value my cargo space, I decided I can come up with the most space if I go with a wide, shallow upfiring design with an aero port facing the rear. This will let me throw a grill over the sub to stack gear on top. I've gone ahead & done a rough design in sketchup, but I still need to figure out port size & its displacement once said & done.
Is there any downfall to having a shallow enclosure ported like this?
Vehicle : 09 mazda 3
Location in the vehicle: behind rear seats, flat on hatch floor
Space available (Length x Width x Height):
  • Length 20
  • width 25
  • height 10
Subwoofer make and model: Alpine SWS-12d4
  • qms - 9.43
  • qes .6
  • qts .57
  • fs 34hz
  • xmax 15mm
Subwoofer Size: 12
Number of Subwoofers: 1
Type of Port (Kerfed, Slot, Aero, etc.): Aero preferred I think, open to suggestion
What type of music do you like?: All styles of electronic - from deep extended low notes, drum & bass, electro/dubstep, & chilled instrunmentals.
Is your goal SPL or Everyday Music?: Everyday music
Tuning Freq (Hz): 32-35? I want to get low but not at the expense of responsiveness & SQ (old pre fab ported sounded muddy)
Volume : Factory recommended is 1.67ft gross 1.4ft^3 net. Proposed design should be around 2.2+ gross
Edited by gen1ms3
Share this post
Link to post
Share on other sites
The dimensions you have give you 2.26cf gross volume. Subtracting sub and port displacement gets it closer to about 2cf net. With a 4 inch round port, you would need about 14-16 inches of port length to get the tune where you want it.
Share this post
Link to post
I would add bracing to that box as well.
Start with 2.26cf minus .11cf (approx) for port disp, .09-.1cf for sub disp and .04-.05cf for bracing, that yields 2cf. A 4x14 port makes a tune of about 32hz. Add more length for a lower tune, subtract length for a higher tune. 32-33hz would be good for your listening perferences.
Share this post
Link to post
Awesome I'll go pick up a sheet of wood & figure out exact thickness & cuts. Thank you!
Share this post
Link to post
You'll need 2 of each of the following sizes:
25x20
25x9
18.5x9
A cut sheet should be easy to figure with that info.
Share this post
Link to post
Update: I went with different dimensions but ended with 2ft^3 after all displacements & bracing. Will be sub up port back. Just have to add two more pieces & do some sanding on port exit to round things over tomorrow when the glue/adhesives cure
Share this post
Link to post
Looks good
Are you joining the panels with biscuits?
Share this post
Link to post
Yea had access to a biscuit joiner so figured they'd help out. Spraying the box down with bed liner now will test it out tonight
Share this post
Link to post
21 minutes ago, THATpurpleKUSH said:
Looks good
What do you think about the sub sitting right over the top of the port opening? He may have enough room to squeeze it in there to the left of the brace idk. Hard to tell from pic..
Oh you have it together now I see
2006 ridgeline hu:KW ddx9903s morel 5.25 maximo comps 6.5 maximo coaxial labc 12 2.4 38hz amp Rf t1000x5ab
work truck 2017 international pro star Alpine ute62 hu. Amps RF t1000.5ad 4 ch mode infinity k1000  sa 15 3.5 @ 30hz or 2 type s12 6.3 @ 41 hz  or jbl s3 2.0 36hz. or nvx  vcw 10 1.1 @ 32hz  2 8 " eminence pro woofers. 2" Dayton rs52fn midrange. 1 1/8 Dayton dc28f silk dome tweeters.
Share this post
Link to post
The hole is cut already. I'll post a pic when it's all put together tonight
Share this post
Link to post
The sub over the port will be ok, they dont look too close together, what i don't like is that wide brace sitting on top of the port, it will restrict airflow in the box.
You should prime with a shellac based primer like BIN so the top coat doesn't soak in.
Share this post
Link to post
Probably will still be better than the prefab he had.
Share this post
Link to post
The brace there is only 3/4 x 1.5" and I did sand over the edges. Didn't think it'd make too much of a difference, though it can be removed & I could pick up a dowel to glue in elsewhere.
I've already started spraying. Going to need another can though which is probably because a bit soaked in like you mentioned... oh well lesson learned. Off to buy another can & finish it up now
Edited by gen1ms3
Share this post
Link to post
Whats up with the brace piece I circled?
Share this post
Link to post
Oh that one... yea that's glued & screwed twice on the bottom & top w/ the pvc fitted through with liquid nails. I suppose I could put a hole saw to it in the largest part there. I didn't want to cut it too short on the sides of the PVC hole in fear of the mdf falling apart
Edited by gen1ms3
Share this post
Link to post
Should I just take a 4" hole saw to this then? Or would multiple smaller holes be better? I don't think that'll effect displacements too much
Edited by gen1ms3
Share this post
Link to post
Man that camera angle. It does look pretty damn wide.
Share this post
Link to post
haha yea, after I took the picture & saw it on my computer I was like damn... Just waiting on recommendation on whether to do one big hole or multiple smaller holes in it 🤷‍♂️
Share this post
Link to post
Cut off the vertical piece where it meets the horizontal piece. That is too much flow restriction. In the future a better design would be to make a flange out of wood and mount the port tube to that to make an assembly and then mount the assembly to the box. You could even use bolts and wingnuts to make it removable like one of my pics below.
Share this post
Link to post
I've never in the 25+ years into car audio seen biscuits involved in boxbuilding. Save that shit for making cabinetry or making house doors. It's almost like seeing people taking simple things then overcomplicating it.
Just a few example pics I made a T-line enclosure a few yrs ago. I didn't use any biscuits, once the top panel is on, it's done.
97 4 dr. Tahoe
Interstate battery
Pioneer DEH-80PRS
Polk Audio MM6501 comps
Wolfram amps coming soon, 3000.1, 125.4
2 Sundown Audio X 15's Tuned @ 30Hz.
Knukonceptz/Royal Excelene wiring
Share this post
Link to post
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
