Need to find the right amp for my setup
  • 2
Slayer16102
CarAudio.com Recruit
34
I purchased a Pioneer TS-SWX3002 12" Preloaded Subwoofer Enclosure Loaded with TS-SW3002S4
The max RMS power is 1500W, but the normal RMS is 400w
The problem I am having is I cannot find a mono amp that equals 75% (1125w) of the peak power at 4 ohms. They don't seem to offer a 2 ohms speaker and sadly most amps I have looked at don't offer very high watts unless you are using the amp and sub in 2 ohms. Can anyone recommend a good amp that can somehow get close to the 1125w needed for 75% of the power. All pioneers subs that are shallows seem to be 4 ohm svc only. For my vehicle setup I must use shallow mount subs due to limited space.
What I am looking for is a good amp for this sub and box setup.
Thanks
Edit: Please move this post to the car audio forum.
infinity k600. 129$ at crutchfield. they are underrated should easily do 400 @ 4 ohms. i own a couple of them myself.  solid reliable little amplifier.i suggest ignoring max power ratings. just useless information imo.`
Thanks
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
242
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
Slayer16102
Slayer16102
fithwheel
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
