Amp in protect
Ra1none
I recently purchased a skar rp 2000.1 to run my 2 fi audio ssd 12’s Wired to 1 ohm on its maiden voyage the amp went into protect . I ran it half gain subsonic 3hz lower than box tune as recommended by fi. The subs were running great with limited voltage drop suddenly it went into protect and I can’t get it out . I disconnected all power grounds and rca inputs per skar let it sit overnight. Took the dmm the every portion of the system and everything checks out . My 4 channel runs just fine with no issues . For a back ground I should mention I have a mechman 240amp alt big 3 plus 2 added grounds a secondary battery with dedicated pos and ground from front battery a stinger 200 batt isolator and 1/0 running throughout . The only thing I can think of is the dual power and ground input reducers I have running to the amp I saw the thread from 2 years ago on this same issue but I checked all those boxes and still nothing can someone please tell me wtf is causing this issue I have no bass and I’m really stumped at this point
Not entirely sure but I know one of the 1-3k skar mono's does this A LOT
There's a defect in the board design that can sort of be fixed
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
Yeah i Yeah I know. I have my sub wired at 4ohm so I can get 300w rms from old amp. It’s 1000w max. And yes that’s the reason I got this pioneer...
40
4K
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
Ra1none
Ra1none
wew lad
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
