Will this power supply be able to power my amplifier?
  • 1
realflow100
CarAudio.com Recruit
62
will this power supply be enough with a supercapacitor hooked up in parallel to power my 12v 1000W DUAL 4-channel XPR84D amplifier? (about 240W RMS per subwoofer. two 4 ohm subs with all 2x2 channels bridged to be stereo)
https://www.amazon.com/gp/product/B07H3NWVG9
or can someone recommend me a better or cheaper option? this one I found has a variable potentiometer so that will be good to turn up the voltage to better power my amplifier.
LMAO.yep,this setup going on over 9 years.appreciate the inspirational quote although i dont take part in water boy memes.
10
801
He wants to use his receiver as a source, not as an amp, so most of your post is wrong.
23
Have you tried connecting the amp to a car battery? No subs, just power. If it protects, amp is bad. If no protect, subs/wiring or ATX power...
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
352
realflow100
realflow100
realflow100
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
