speakers not working
  • 4
poorman
so I got my stereo hooked up it turns on and the stereo I had before was a custom stereo and everything worked but when I got my new one set up it works but dont have sound coming from speakers it has the bass to my subs but no audio I have 1 blown speaker before the new stereo but now they all aren't working does anyone know what could be wrong
Lots of issues could be assumed here, if not sure, you can attach pics of the install, are you running external amps or just being powered from a head unit.
Do you know how to use a multimeter as it will make your life easy if you are into DIY install???.
Let us know more details as it hard to provide possible causes unless we know what components are involved here.  You have to be patient with car audio as parts do tend to get loose so good installation is the main key when you are trying to achieve decent sound in an automotive environment,  that's why soldering connections, property wire gauge and distributors are used. So is sound deadening and speaker placement.
Cheers mate!
Did you say you dropped it off at the autoshop? Well that's the problem. Not all all mechanics are made alike. Even if they are ASE certified...
238
It may be that they act like this because they are underpowered and the push to play them louder is causing the amp to clip the signal, which will...
190
poorman
poorman
DRBOOM
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
